v6 freelander starting problem
L
lindy33
hi, im having starting problems , when from cold it starts fine but after it is stopped it will not start, it used to take about 5-10 mins but now im waiting about 3 hours, there is no spark when the problem is there, i have changed the crankshaft timing sensor and it made no difference then i changed the engine temp. sensor and it went fine for 4 days then did it again, it cranks over, the fuel pump is herd running just not sparking, then it will fire up as if there had been nothing wrong, any ideas would be greatfully appreciated. thanks
