Tyre pressures
D
dabollicks
What is the recommended tyre pressures for a freelander?
Cheers
T
tkcomp
Do you have the original tires on your Rover or same make/model tires the Rover came with? If so, open the drivers door and you will see a black label that will display the perscribed tire pressure. The tires on my Disco say 40 but the sticker on the door says 28.
Check to see if you have a sticker on the door of your Freelander.
Keep us posted!
Tom
D
disco1
Tyre pressures are a subjective thing, based on type of terrain and load carried.
FWIW, for normal on road use, I like 38-40psi all round, and, have had no issues with uneven wear or road handling.
