Turkey Baster?
lowwill
Have any one used this to change out fluids? Brake and p/steering? If so do you have to bleed the brakes or just change out as much as you can and fill back to the line?
lowwill
Hey Joey so you just sucked all the old stuff out and put new stuff in.
Muddyone
Land Rover Sales Consultant
Waterloo
I had a bleeder from a store but it didn’t work to well so i just ended up getting a line off of the caliper and getting someone to pump the pedal until the fluid wasn’t dirty anymore, keep on refilling the reservoir with fresh fluid. Get a deep bottle or jar and make sure the line is under the fluid so there is no bubbles and then just close the valve when you’re done takes like 30 secs that way lol
On a D1 you can use either the bleeder if there is only one person or the line way if two people... on the D2 you have to have Testbook or similar LR Computer to activate the ABS pump.
gvillalongo
