Td5 trouble
tapasr_567a95aef
Hi there, I've just got my gear box repaired, with that I've replaced: dual mass flywheel, spigot, crank seal, transferbox seal. I've replaced sump seal. The car will start and when I rev it a bit and engine light came on. It will also cut out. I went to a dealer and got them to use a obd readerm they said that the crank sensor band and air flow sensor needs to be replaced. So I've done that and the same thing happens. I've also replaced the injector harness band gasket as there was oil traces on ECU. Please help.
Sent from my ONEPLUS A5000 using Tapatalk
gvillalongo
