SYA Kit, Oversize Tires and Stability Control
Michael Gain
Clarksville, TN
Know it's been awhile since I've last posted, but thought I would chime in.
With the strut spacer and 2.5 in lift rods, the height sensors are already showing the computer a different voltage than stock. You're just calibrating the sensors to the new height. You are not manually adding +64mm, but rather ensuring that each corner is calibrated to the new height. It should already be close to the +64mm all around; you are just ensuring that this is the case and assigning the new voltage value accordingly.
I cannot speak to the traction control issue. As, I did not experience it. The methodology above merely ensure complete travel of the vehicle: access, normal, and off-road height; without the vehicle computer thinking that you have bottomed out.
@djkaosone is absolutely right. You need a GAP tool.
I would encourage you to look at other threads across the internet. That is how I found the +64mm methodology. I cannot take credit for it
Expedition portal and AULRO have a wealth of knowledge, including a couple of threads on the SYA kit.
CaliLee
Santa Cruz Mountains
Thanks Michael,
I'll continue my research. My tire choice may be contributing to this as well, I have 255/65R19s on there. 32' tall and a bit on the narrow side.
Lee
greiswig
Supporting Member
Supporting Member
SW Washington
I doubt your tires are your issue unless they are inflated wrong. I have 275/70R18s and don’t have the issues you describe.
