Suspension Fault
johnstmark
Hi All, I need any help you can offer.
I have a 2006 Range Rover Sport HSE with only 35,000 miles.
Every day or two, the Suspension Fault warning light comes on and stays on. Sometimes it turns red and says do not exceed 30MPH. I cannot tell any difference in handling.
The "lower to enter" function will work if the light is not on.
Now, it seems that the passenger side of the car is lower than the driver's side when parked.
The repair shop supposedly replaced a sensor, but does anyone have any idea what might be causing this and/or how to remedy?
Thanks so much!
Sounds like either a sensor or a possible leak in an air bag. either find a good rover shop or you can get some soapy water and find the leak... if a leak, order new air bag and replace.
