Suspension Fault - Access Mode
Neil Couvillion
Alabama
Good morning,
I have a 2012 LR4 with a Proud Rhino Lift and have had 0 issues with suspension faults until yesterday. I was parked in my drive and when I hit access mode, it threw a suspension fault. I restarted and it went away. It will go in to offroad height and lower back down to normal height, but when I try to go to access mode it throws the fault. I have not experienced any issues driving.
I do not need to go to access mode, so it isn't an issue but knowing that it has this fault, is bothersome to me.
I have not pulled a code and will try to do that in this week. I just got the GAP tool and have not set it up.
Anyone experience this as well?
Thanks in advance.
Neil
f1racer328
AZ
Have you been into access mode with the lift rods installed before?
I'd pull the codes as there could be a lot of reasons it's throwing a fault. The IID tool is pretty easy to setup.
Neil Couvillion
Alabama
I have had the rods on for over a year with no issues going into access mode before. I'll get it set up and follow back up. I appreciate the response.
tflint2112
