Suspension dropped while in traffic
Rover Range
Texas
How to set the tight tolerance mode;
  1. Put the Gearbox in PARK
  2. Start the engine
  3. Set the suspension to Normal Height
  4. Open the driver’s door
  5. Press the brake pedal lightly 3 times, letting the pedal come up fully each time
  6. And close the door within 10 seconds from first press of the brake pedal
  7. There will be 2 chimes from the instrument cluster after the door is closed, if successful
  8. Each time the door is opened and closed, 2 chimes will sound, indicating it is still in tight tolerance mode.
  9. To deactivate:
    1. Either turn the engine off, or drive it over 5 mp/h
    2. If you were to use this procedure for wheel alignment, you need to have the engine running the whole time.
f1racer328
AZ
  2. Start the engine
  9. To deactivate:
Haha didn’t know that you could do it like that. IID tool can do it as well.
dimitricourmousis
