steering wheel not straight
disc03
my 03' disco steering wheel is not straight.do i need a front end alignment?
thank you
Just needs the steering linkage adjusted... not an alignment.
discomk
how to adjust steering linkage, please?
I will get out this morning and take a picture of what you need to adjust. about 5 minutes work... mine has been off for about 5 years, just never seem to get around to adjusting it. Thankfully one has nothing to do with the other... (steering wheel being straight and the alignment).
Also anyone can align a D1 or D2 at home just remember it is set to zero... measure the distance between both front tires (front of tire, and back of front tire... they should be the same distance across.)
Do you have the Current RAVE CD? If so check out page 711 and 712 it explains how to centralize the steering.
I am sure I have posted the link on here somewhere... search for manual in the disco section with me as the poster.
discomk
thank you, joey. i will check in the RAVE CD.
Disco2TrailEdit4
