Some codes to decipher
ycharlie
Hi guys, my backup cam just showed up blue today. When I went into the menu I saw all other cams except the mirror cams blue. Scanned for codes and found this. Any ideas:
2010 LR4
ACM-Audio System
  • U2100-00 (2B) Initial configuration is not complete
    ( on 09-03-2020 21:38:56 at 158156 km )
  • U0159-00 (2A) Lost communication with parking assist control module
    ( on 09-03-2020 21:38:06 at 158156 km )
FEM-Navigation
  • B119F-13 (2F) GPS antenna - General electrical failure - circuit open
    ( on 09-03-2020 21:38:04 at 158156 km )
  • U2005-62 (2C) Vehicle speed - Algorithm based failure - signal compare failure
    ( on 23-12-2019 17:30:49 at 153224 km )
IPMB-Camera
  • B12BD-31 (2F) Rear camera - Frequency modulation/pulse width modulation failure - no signal
    ( on 29-02-2024 20:38:47 at 0 km )
  • B12BE-31 (2F) Front left camera - Frequency modulation/pulse width modulation failure - no signal
  • B12BF-31 (2F) Front right camera - Frequency modulation/pulse width modulation failure - no signal
  • B12C1-31 (2E) Right mirror camera - Frequency modulation/pulse width modulation failure - no signal
    ( on 09-03-2020 21:40:03 at 158156 km )
PCM-Engine Petrol
  • P0106-00 (A8) Manifold absolute pressure/barometric sensor range/performance
Now, a few things first. I am aware of the gps module code and I've disabled my TPMS since without GPS it won't recognize them anymore. as for p0106 I've actually changed the sensor and the code went away, but came back again. Perhaps I need to clean that part out. As for the rest, I am stumped.
Any ideas would be greatly appreciated!
Strizzo
Texas
Friend of mine had the map sensor code and ended up having to clean the throttle body.
All the lost connection codes seem like it could be either a low battery or if you’ve disconnected the battery recently and it messed with the config
