Rear window problem
pabs406
Hi Everyone. Just wondering if anyone has experienced this problem. My back window is acting up. The rear window is supposed to drop a couple of inches when the button is first pushed. Then drop down all the way when pushed again. Then roll all the way up when pushed again. The window behind the passenger works fine.
However, the window behind the driver side just started to act differently. When the button is pushed the window rolls all the way. It doesn't stop a couple of inches. When rolled up the window stops every 2-3 inches. It doesn't roll up continuously like it should.
Could a simple reprogramming fix the issue?
Pfunk951
Sounds like a switch to me.. Does this happen when controlled from the driver's seat switch and the rear switch?
Mike
jaguardoc504
Sounds like a programming issue.
Roll the window all the way down and hold the button down for 10 seconds (from the drivers switch)
Then proceed to roll the window all the way up and hold the button for 10 seconds. If that doesn't fix it, sounds like the drivers switch is bad.
pabs406
Thanks Jag. It worked just as you stated.
