Rear suspension leak
Stevorino33
Washington state
So I just put new o rings in the rear valve block my rear air struts are also new. And the rear still sags. I pulled the air suspension fuse about 8 hours ago and so far it’s still at the same off-road height neither side has dropped. I’ll leave it overnight and maybe things will change by morning. But if they don’t what else should I check. I’m probably gonna double check the valve block hoses first. But let me know if anywhere else can be a problem area. Thanks in advance
Cthehentz
Las Vegas
Did you look at the center valve block? The center valve block will feed front, rear and air tank.
Stevorino33
Washington state
I haven’t yet I do have the o rings for that as well. That would explain why it didn’t lower when I removed the air suspension fuse too right?
NorthwestDriver
Seattle
Check the Voss fittings into the rear valve block. It’s very common for at least one to leak after messing with them.
