Rear brake job - ebrake in service mode?
Quijote
Metro Boston
Later this week I'll tackle a full rear brake job. My 2013 LR4 is 6.5 years old with 42k miles. I replaced the rear pads with OEM pads at 22k miles and 3.5 years ago.
I have OEM rear discs and bought EBC yellow pads for the rear. But I just noticed that those pads did not come with the retaining clips or new hardware. I can't seem to be able to buy just the those items either. My plan was to reuse the existing stuff with some cleaning and new thread lock.
My question has to do with the e-brake. Atlantic British video suggests that the process is really no different than on older cars. That is, retract the e-brake shoes, replace disc, re-set the e-brake shoes and gently bed them. However, I was under the impression that the e-brake system had to be in service mode the shop manual for 2011 Disco's suggest the same.
Thoughts?
Waterndirt
When I replaced my rear rotors on my 2015 I put the parking brake into service mode. No problems or issues. Everything went smoothly.
Quijote
Metro Boston
Cool. Thanks. I found Bodsy's Bible.
In short it does need to be in service mode.
I didn't bother with any of the fancy procedures and replaced rear rotors and pads. I did adjust the parking shoes. Brakes work, parking brake holds on steep hills. Key is: Don't touch the EPB switch while working on rear brakes. Easy.
JARentDTOM
NKY-Cincinnati
I think Service mode is preferable, I changed my ebrake shoes when disengaged. Don’t mess with the switch while working on them. If you run into problems send me a message. Take picture before, I have a video of putting them back on that I need to post.
Bodsy
UK
When I replaced my rear rotors on my 2015 I followed these instructions. No problems or issues. Everything went smoothly.
thanks to
DOOMSDAY OVERLAND
Specialist Land Rover and Range Rover Support
for copying my instructions without crediting the original free document.... :dontknow:
Waterndirt
thanks to
DOOMSDAY OVERLAND
I removed the file and will change credit to you. Thank you for your write up, helped me a lot!
Easycool
Mesa, Arizona
Ok, 2 things,
1. Where can I find Bodsey's Bible and,
2. How do you put the ebrake into service mode?
2007 Range Rover Full Size 4.4l petrol.
