Questions About the 2013
Quijote
Metro Boston
Hey everyone,
I am currently away in Boston, but before I left had a slight problem with the auto-up and down feature on my windows. I know sometimes they have to reset the windows from the factory, and I found how to do that in the manual, but the auto- up and down seem to be a bit touchy? I have to do such a quick pull up and let go of the button in order for it to work.
Has anyone had this problem with their 2013? Do you think I need the dealer to program it or should I try a reset again?
Beside that, I need to figure out my top latch - it's pretty tough to close and requires a really firm push.
Any help would be appreciated. Thanks!
Regards, David
I'm of no help, but welcome to Boston!
David, try a reset again of all 4 windows. Just like the manual says, the one-touch up/down feature of mine stop operating randomly (one, two, or all windows) whenever I disconnect the battery to work on the car, which I have done often while installing my aftermarket mods. The sunroof one-touch function usually stops working as well. Resetting all of the windows and the sunroof - even those that appear to work after a battery disconnect - by following the manual's instructions has always worked for me.
Thanks!
I was born, brought up, and went to undergrad here so it is home. I moved to CA about six years ago, but will likely move back at some point. It's funny, on my drive on the Mass Pike I saw 2 brand new Range Rovers. The Firenze Red is quite nice! :)
-David
Thanks, Umberto.
I did follow the instructions in the manual right before I left for the airport, but will try it again when I return (as well as the sunroof). They were working, but really touchy. Hopefully another reset will help.
-David
Hey Umberto,
I am back from Boston and reset all the windows and sunroof - works great. Thanks!
-David
Hi everyone,
I know this was mentioned previously, but I can't seem to find the post. Is it typical that when the side mirrors fold upon locking that they gently hit the window glass?
I wish I could figure out a way to stop the automatic folding - I think the IID tool can do this?
Thanks!!!
-David
The driver side mirror on my 2013 does contact the window glass when folded. The passenger's doesn't. Indeed, that feature could be disabled via IIDTool or Faultmate (and by a dealer, if you ask them) by changing the foldback mirrors program from "Fitted w/ Logic" to "Fitted." But like others have said, I like the visual cue that I remembered to lock the doors of the car when I see my mirrors folded from a distance.
Thanks, Umberto!
You are always so helpful - I can't thank you enough. I took a look and the same is true for me, the driver's side mirror slightly touches the window glass, while the passenger side mirror does not. I am just glad it's meant to be that way. ;-)
I will keep them folding, as I see your point about making sure the vehicle is locked.
I am heading to the dealership on Friday to have them fix my wood trim, so I wanted to make sure everything else is working correctly.
On another note, I am heading to Oakhurst, CA on Saturday, June 22nd to get my roof rack, ladder, and sliders installed. Then, the following week getting my Coopers mounted. I am likely going with the 18" wheels, but not until next year.
-David
