misfire - arc between ignition coils and metal
whiskeynipple
when it is foggy or misty upon start up I get misfires for the first several minutes -- until the engine has heated the engine compartment - hence removing the moisture -
I can visually see an arc between one particular coil pack (rave manual - section 19 pg 8 no. 2) and the metal rail upon which they sit. I cannot tell if it is coming from under the spark plug wire or a tiny ( i cant see one) crack in the plastic housing of the ignition coil.
what I have done:
- replace spark plug wires ( firmly seating each one - and re checking)
If the housing for a inginition pack is cracked - epoxy? ( can I take it apart)
How many miles on the engine and what brand of wires did you install?
whiskeynipple
84000 miles and they were OEM duralast -
note - I had this issue prior to replacing the wires thought the wires would solve it -
the arc seems to be coming from either under the wire boot or a hairline crack in the ignition coil
Time for a new coil and those Duralast wires won't last long, I would change them going either to a STI or a Magnacor 8 mm wire.
greg409
I don't know which duralast wires you've got, I had the $50 autozone silicones on for over
5yrs. --- still fine
Did your's have the di-electric grease in the boots?
(Helps prevent arcing)
Do you have an inspection mirror? (carbon tracking would be present with a crack)
An led flashight seems to show details better for me.
luck,greg
