Leftover 2015 LR4 Parts
Michael Gain
Clarksville, TN
Thank you for all of the interest! The new LR4 owner came by today and here is what is left / claimed:
OEM center driveshaft. Carrier bearing is slightly sagging, but would be a good spare / rebuild ($20, local pick-up only)
10 x bottle of Motul ATF VI. Compatible with the ZF transmission. ($50, pick-up only)
1 x 4oz bottles of supercharger oil. The supercharger only takes 3.4oz (Greiswig)
BG fluid kit; 44K, MOA, EPR and funnel (greiswig)
2qts Royal Purple 75W90 ($10 ea shipped)
1qt Royal Purple synchromax. Compatible with one-speed transfer case. ($10 shipped)
OEM LR109354 Passenger-side valve cover. SCV6. Comes with valve cover gasket, all bolts (-2 for some reason), and mega black RTV sealant. ($120 shipped)
LR010735 OEM oil filter housing seal (greiswig)
Exhaust manifold gasket replacement kit (will break up if someone is interested): LR052347 and LR052348 left and right exhaust manifold gaskets, QYG500100 and QYG500110 upper and lower steering shaft bolts, 12 x LR034008 exhaust manifold bolts, 4 x LR010805 exhaust manifold bolt spacers (in case you lose any spacers while doing the repair), and WCM500110 catalytic converter gasket (only one on the vehicle) ($150 shipped)
Corteco Motor mounts. If you are doing the exhaust manifold gaskets, you may as well replace these while you are in there ($90 shipped)
JLR9899 fuel injector seal tool. (greiswig/cbkearney)
Fuel injector removal tool. Worked flawlessly (greiswig/cbkearney)
2 x Bosch fuel injector clips and 3 x OEM fuel injector seal kits (greiswig)
4 x used fuel injectors. 2/6 replaced to fix my misfire. I replaced the other 4 as preventative maintenance. ~65,000 miles. ($30 ea shipped)
OEM above alternator idler pulley and cover (just pay shipping)
OEM front crossover pipe kit (Brand New): LR090630, LR092992, LR011038 ($90 shipped)
6 x Delphi ignition coils. Installed as part of my misfire diagnosis. My truck did not like them. Yours might. I replaced with OEM ignition coils. ($150 for all 6 shipped)
6 x used OEM coils. The misfire was caused by two faulty fuel injectors. These are still good as a backup set. ~65,000 miles ($100 for all 6 shipped)--3 x claimed by greiswig
8 x 5mm hub-centric wheel spacers. These do not have the hub-centric lip for the rim. (just pay shipping)
Fan clutch wrench and holding tool. The wrench worked perfectly. The holder tool would work as long as you loosen the fan clutch in the right direction (greiswig/cbkearney)
Corteco axle seals Front or Rear. Came in the kit with the rear diff pinion seal. (greiswig)
Britpart brake switch. Box is pretty beat up from being in my spare parts bin. (greiswig)
Michael Gain
Clarksville, TN
Updated list of available parts:
NEW OEM LR109354 Passenger-side valve cover. SCV6. Comes with valve cover gasket, all bolts (-2 for some reason), and mega black RTV sealant. ($120 shipped)
NEW Exhaust manifold gasket replacement kit (will break up if someone is interested): LR052347 and LR052348 left and right exhaust manifold gaskets, QYG500100 and QYG500110 upper and lower steering shaft bolts, 12 x LR034008 exhaust manifold bolts, 4 x LR010805 exhaust manifold bolt spacers (in case you lose any spacers while doing the repair), and WCM500110 catalytic converter gasket (only one on the vehicle) ($150 shipped)
NEW Corteco Motor mounts. If you are doing the exhaust manifold gaskets, you may as well replace these while you are in there ($90 shipped)
USED OEM above alternator idler pulley and cover (just pay shipping)
NEW OEM front crossover pipe kit (Brand New): LR090630, LR092992, LR011038 ($90 shipped)
NEWISH 6 x Delphi ignition coils. Installed as part of my misfire diagnosis. My truck did not like them. Yours might. I replaced with OEM ignition coils. ($150 for all 6 shipped)
3 x used OEM coils. The misfire was caused by two faulty fuel injectors. These are still good as a backup set. ~65,000 miles ($60 for all 3 shipped)
