Leftover 2015 LR4 Parts
Michael Gain
Clarksville, TN
As most of you know, I traded in my 2015 LR4 LUX and have quite a few leftover parts. The new owner has the first right of refusal for a couple of items, but I have annotated them appropriately below. I am located in Clarksville, TN 37040 for those that wish to pick up items, and for the larger items that I am too lazy to figure out how to ship. I prefer paypal. Pics upon request. PM me with any questions, suggestions, requests to combine items, etc.
5 x 19”, twin spoke, OEM wheels with TPMS and tires ($200, local pick-up only)---reserved for new LR4 owner
OEM center driveshaft. Carrier bearing is slightly sagging, but would be a good spare / rebuild ($20, local pick-up only)
10 x bottle of Motul ATF VI. Compatible with the ZF transmission. ($50, pick-up only)
3 x 4oz bottles of supercharger oil. The supercharger only takes 3.4oz (just pay for shipping)
1qt LR front diff / non-HD rear diff oil (just pay shipping)
BG fluid kit; 44K, MOA, EPR and funnel ($30 shipped)
2qts Royal Purple 75W90 ($10 ea shipped)
1qt Royal Purple synchromax. Compatible with one-speed transfer case. ($10 shipped)
OEM LR109354 Passenger-side valve cover. SCV6. Comes with valve cover gasket, all bolts (-2 for some reason), and mega black RTV sealant. ($120 shipped)
OEM trailer brake control harness. No install instructions ($30 shipped)
OEM from bumper air diffusers. Removed to increase forward ground clearance ($20 shipped for the pair)---reserved for new LR4 owner
OEM lift rods (just pay shipping)
LR010735 OEM oil filter housing seal (just pay shipping)
AC Delco oil filter ($5 shipped)—Reserved for new LR4 owner
Oil filter wrench. ($10 shipped)---Reserved for new LR4 owner
BT GAP IID Tool. Will need to pay for transfer license ($250 shipped)---reserved for new LR4 owner
Exhaust manifold gasket replacement kit (will break up if someone is interested): LR052347 and LR052348 left and right exhaust manifold gaskets, QYG500100 and QYG500110 upper and lower steering shaft bolts, 12 x LR034008 exhaust manifold bolts, 4 x LR010805 exhaust manifold bolt spacers (in case you lose any spacers while doing the repair), and WCM500110 catalytic converter gasket (only one on the vehicle) ($150 shipped)
Corteco Motor mounts. If you are doing the exhaust manifold gaskets, you may as well replace these while you are in there ($90 shipped)
JLR9899 fuel injector seal tool. ($30 shipped)
Fuel injector removal tool. Worked flawlessly ($40 shipped)
2 x Bosch fuel injector clips and 3 x OEM fuel injector seal kits (just pay shipping)
4 x used fuel injectors. 2/6 replaced to fix my misfire. I replaced the other 4 as preventative maintenance. ~65,000 miles. ($30 ea shipped)
OEM above alternator idler pulley and cover (just pay shipping)
OEM front crossover pipe kit (Brand New): LR090630, LR092992, LR011038 ($90 shipped)
6 x Delphi ignition coils. Installed as part of my misfire diagnosis. My truck did not like them. Yours might. I replaced with OEM ignition coils. ($150 for all 6 shipped)
6 x used OEM coils. The misfire was caused by two faulty fuel injectors. These are still good as a backup set. ~65,000 miles ($100 for all 6 shipped)
Aftermarket battery tie-down. Came with the Traxide kit, but I used the OEM bracket. (just pay shipping)
8 x 5mm hub-centric wheel spacers. These do not have the hub-centric lip for the rim. (just pay shipping)
30”-33” spare wheel cover. I bought two and the other is still going strong. ($20 shipped)
Fan clutch wrench and holding tool. The wrench worked perfectly. The holder tool would work as long as you loosen the fan clutch in the right direction J ($20 shipped)
OEM start / stop battery and bracket. Removed for my Traxide install (make an offer, pick-up only)
2005-on Range rover sport brake pads and hardware. Leftovers from when I installed the range rover sport brake calipers on my wife’s LR4. (Reserved)
Corteco axle seals Front or Rear. Came in the kit with the rear diff pinion seal. (just pay shipping)
Britpart brake switch. Box is pretty beat up from being in my spare parts bin. (just pay shipping)
I also have a mityvac and multiple suction guns, but I am currently reserving them for the new LR4 owner.
Michael Gain
Clarksville, TN
Attaching pictures
