Language settings/clock reset itself overnight
vindio
Has anybody gone to start their LR4 to find the settings/clock reset overnight? I suspect a battery issue, but the vehicle cranked and started okay (a bit slow, as it's cold in PA).
I'm going to replace the battery today just in case (it's a 4-yr old DieHard AGM), but want to make sure I'm not missing something more obvious.
The LR4 runs great otherwise! (140K miles)
v
Probably the battery, even if it started. Things start getting weird in the weeks before the battery finally goes.
How old is the battery?
vindio
The battery is exactly 4 yrs old.
Seems like with an LR4, anything more than 2.5 - 3 years is on borrowed time.
vindio
Went to Sears to get a new battery, and they noticed that one of my terminals (the one closest to the firewall) was loose, and won't tighten it. Apparently it's a "smart terminal" that only the dealer can replace? Does that sound right? Will take another look tomorrow.
v
Tnt47
Salk lake county
v
Did you ever figure out why this was happening and if so, did you find a solution?
jlach993
Fresh Meadows Queens NY
My symptoms were time reset, and the absence of HD radio. The HD radio came back after the battery was swapped. I have no idea what the correlation is.
tango90
