Iginition "Thump"??
redrover51
When I turn the ignition on, there is a distinct "Thump", or bump sound coming from behind the dash....drivers side.....I didn't hear this in my D11.....any ideas?
D
discomike
Are you talking a thump like the starter is loose and the bendix is not hitting the flywheel right and or the starter is torquing on it's mounts???
Mike J.
redrover51
No Mike, it's like a very muted electrical, or small thump INSIDE the dash, behind the guages somewhere. it occurs just after I get power to the ignition, not when engaging the starter. It's wierd, it sounds kinda-like someone taps once very lightly behind the speedo area. It only does it once, then I proceed to start... Ideas?????
D
discomike
How about the ABS system doing a self test, it will give a real muted thump?
Mike J.
redrover51
That's probably it....it sounds like a pressure switch, or a fuel pump loading-up. I'll keep my eyes on it and wait to see if anyone else notices the same noise....Thanks for your input.
gvillalongo
