BTW: for future reference here is how its done
1) go to NAPA store and pick up double sealed bearing (Justin, yours was single side btw)
2) remove upper portion of fan cowl, remove serpentine belt
3) depending on how badly its stuck - you can either use 15mm socket wrench (regular direction) to undo onlly pulley, or use 13mm wrench to undo tensioner assembly and then pulley off from assembly.
4) get C clip out - its on wider side of pulley
5) with C clip out of the way push bearing off. Can be done with rubber mallet and wrench' socket as pusher. Mind to push out via wider side.
6) stick new bearing in. Wither use machine shop of socket and mallet solution. If socket - then it has to be just tid bit smaller than outer bearings dimension - so you wouldnt damage side seals
7) pick up bit of grease and cover both sides of bearing and inside hole. Good grease, not cheapo one
8) put C clip back in, bolt pulley onto tensioner assembly.
Viola. You got quieter pulley.
Hint - if pulley stuck badly - take assembly out. Soack it in WD-40 or BG penetrating solution. Get 6-side 15mm socket wrench, put assembly under hi-lift, stick one of ends of hi-lift under wheel, and ask friend to stand on other end - this wills secure assebly - start unbolting... Can try to use air socket thingy as well..
