HID lamp not working
Quijote
Metro Boston
Is it more likely that the lamp itself failed, or something in the system, like the ballast?
Are HID's (all aspects of it) covered under warranty, or will I get an obnoxious bill for something I could have troubleshooted/replaced myself?
Just want to know if I should bring it in or not?
I have a 2013 under warranty until late 2017.
Well, the easiest way for you to find out would be swapping left and right bulbs around, then you'd know for sure if it's a bad bulb or something else not working on that side... But if your factory warranty is still valid, it should cover both the xenon bulb (which may be considered a wear part if it wasn't so darn expensive...), ballast, and wiring, so you should probably let the dealer figure it out.
