Hesitation Only When in Reverse After Long Drive??
Salanizi
Kuwait
Hello
I would appreciate any insight on this issue as i have already replaced every part under the sun on this car.
My previous rough idle was only fixed after removing the cylinder heads and having the valve seats machined and fixed.
Since then I also replaced all the injectors with new Bosch ones, as well as the remaining unchanged O2 sensors with Bosch ones.
Everything has been fixed with the car the only remaining thing is the hesitation in reverse after a long drive.
Could it be something with the transmission (already serviced)? Or is it definetly engine related?
I am not getting a CEL for this issue.
This is not happening if i put it in reverse after a short drive when the engine is still cool
Thanks
