Fuses
....should there be slots in the fuse box that are empty? Meaning the graphic shows that there is an active icon-slot there but there is in fact no fuse?
I believe, for example, my F6 is missing.
Anyone?
Thanks in advance.
thorgal
F6 is for Petrol engine with coils, according to a manual..
F21 is a spare
bbyer
Alberta
probably no power there
You will probably find that the empty slots have no power going to them as well as being empty of a fuse. I discovered that when I figured they would be good sources of power and came up empty.
I assume the F6 you are referring to is what I would call F6P in the passenger side interior fuse box. I see that is called up as a 10 amp Tow Reverse Lamp which sounds kind of European to me, hence not in the NA Spec vehicle.
As such, I ended up using those Mini Add A Circuit fuse taps which do seem to work quite nicely and look fairly neat as well.
Bostonian
One thing I did not realize is that there are addl fuses behind the glove box. I found this out while changing the cabin filter. No, I never read the manual. I have an 06.
