Fuses
Hello Everyone,
It seems that when I use my rear 12V power outlet (in the back cargo area) with my portable air compressor, it blows a fuse. This also happened on my 2011 as well. I need to buy some spare fuses, but any suggestions? Everything is fine if I use the front 12V power outlet, it's just in the cargo area. Thanks!
-David
RoverGuy7
Yes, those will work, but do not use a higher rated fuse to keep it from blowing.
Thanks so much!
Should I be maybe shutting off the radio, etc. when using the back 12V plut? Am I trying to pull too much juice? I am only using an air compressor meant for a 12V plug.
-David
Kaaae
i plug my compressor into the battery (like jumper cables), until i do the second battery mod.....
drivesafe
Hi David and what is the current requirement for you compressor?
RoverGuy7
The only other thing on that fuse is the other power outlet in the console, if you have anything plugged in there, take it out before powering up the compressor.
It's a 20A circuit, so you should be using a compressor that is rated below that, or 240W.
Also, using it with the engine running may help if it is running and then blowing the fuse after a few minutes.
I need to do this as well. I know I saw a few good air compressors with clips - much faster than 12V.
Thanks, RoverGuy!
My air compressor is rated for 240W. I always use the air compressor with the engine running and do not have anything plugged in except my small portable flashlight (in the front console) and a USB plug - though both are not taking juice at that time.
Any hints on changing out the fuse - I would imagine I just look in the manual, pop out the old fuse, and pop in the new one.
I ordered those fuses I posted above.
-David
gvillalongo
