Faults code engine Range Rover 1995/1998
pascaltissot
Engine faults codes for Range Rover 4.6 HSE 1998.
Does any of you have this info ,just to have it handy in case I need it when I use my Autologic diagnostic computer ,the Autologic does not have a code resume , I just usually use the electric fault manual ( and believe me it is not fun to find the code, and once you find it ,you are just as you began #$%&9)Sorry, I suppose I am not smart enough..
Ha ha .
Saludos
Pascal.
Check this page for code info... but the autologic should tell you what the codes are...
http://www.iequus.com/
pascaltissot
Joey, you are right the Autologic gives me the codes number but not any clear explanation on what it is , like I told you before you have to search in you electric manual ,but what I was talking about is that I saw a very good resume off engine fault codes for Discovery and I thought it would be good to have the same for a Range rover P38. Don’t you think?
Pascal
have you check with www.rangerovers.net ? they have a lot of good RR info... not that I am trying to push anyone away from here, but they do have some very good info there.
