EPB woes
roverman
Sometimes yellow light on, sometimes yellow light on and red light blinking. Sometimes yellow light off and red light blinking. Sometimes no lights on until I come to a stop and red light blinks and audible beeps. Parking brake doesn't work - unless I'm moving in which case it has worked a couple times.
Enough to drive you crazy
To top it off, the mechanic can't get either of his code readers to pick up my car at all. His readers have worked on it before. Could the EPB fault POSSIBLY be the reason for the difficulty connecting the code reader??
This sounds like a different variety of EPB issue than I've heard of. Typically the actuator goes out due to stripped (plastic) gears and when failed it howls like a banshee. It's a fairly cheap replacement.
I'm not sure that the EPB could cause the reader to not connect with your vehicle; did it ever connect before? Maybe it just doesn't speak Rover.
roverman
Code reader needed reflashing, works now. "Lost communication with parking brake module". Don't know if it's corroded wiring or a bad module itself. But I have one on order so will see soon enough.
gvillalongo
