Ali Zafar
My 2001 TD5 Defender's air conditioning fan turn on as soon as I switch on the ignition and keeps running even if I have the air condition off. And it only turns off about 5 seconds after the ignition has been turned off.
I have this vehicle from new, originally the fan only worked with either air conditioning or if the coolant temperature rose past the capabilities of the viscous fan.
Kindly advice where should I look to fix this?
