Coolant Drain and Refill for 04 Disco HSE7
discomk
At 60K now. Time to flush out the coolant amount all other fluids. Can't seem to find the drain plug... :confused: any pictures on how to and etc, please? :biggrin:
Coolant doesn't have a drain plug, just remove the bottom hose.
discomk
disconnect the hose, drained it; ran with gardening hose until its clear water came out (with the engine on heater on Hi); fill the coolant up while the engine's still running until color changed from clear to coolant again; turn off the engine; connect the hose back, top up the coolant; start the engine and check the coolant level. check and top up again the next morning.
radiator flushed! i didn't do anything bad there, right? :p
Other than the water from the hose... you should always use distilled water to fill the radiator.
helge
