- Joined
- Mar 1, 2004
- Posts
- 813
- Reaction score
- 1
Cleaning Your Land Rover's AC drain lines
Thanks Andy Maier (Moose)
Many people have problems with mist coming out of the vents, and heavy condensation or leaking on the passenger side of their trucks after using the air conditioner. The likely cause of these symptoms is a clogged A/C drain line.
The drain line runs water from the A/C system to the bottom of the truck, which allows condensation from operation of the A/C to drain out of the bottom of the vehicle while it's in motion (it causes the puddle of water people see under cars in the summertime). The drain ****** at the end of the line on Discoveries can easily become clogged, leaving the extra water nowhere else to go. Here's how to clean the ******:
TOOLS NEEDED: None.
TIME NEEDED: 5 minutes at worst.
DIFFICULTY: Can you turn an ignition key? If so, you can do this one.
PROCEDURE:
(1) Get under truck from passenger side;
(2) Look near front (engine) end of transmission -- there is a rubber pyramid-shaped piece without anything else near it (see picture one). This is the drain ******.
(3) To clear a clogged ******, use your finger or a small tool to wiggle the ****** until the mud, dirt, debris, etc. is freed, allowing water to flow out. This water is dirty and may be warm.
(4) Allow water to drain out, attempting to dodge as much as possible.
(5) Check periodically to ensure water flows from the drain line, cleaning as necessary.
(6) Wipe arms off with towel.
HERE ARE PICS:
TOOLS NEEDED: None.
PROCEDURE:
HERE ARE PICS:
