Anti-freeze leak of some kind
D
Danit
I have been noticing a strong smell of anti-freeze in the cabin. This smell sometimes goes away after heating has been on for five minutes. However, after the engine has stopped the smell, comes back. I have checked interior for leaks and underneath car but no sign, also I have checked radiator and the expansion tank tank all of which appear fine. I am still looking for what is causing the anti-freeze smell.
Slam
Supporting Member
Supporting Member
Your heater core has probably failed and is leaking coolant. Replacing the heater core should fix your problem if that is the case. GOOD LUCK!
gvillalongo
