another drain hose dilemma :(
CATTIVA73
How do I access the pass side sunroof drain hose now that the side vent has been replaced by an ARB snorkle by p.o. ??? when I checked the drivers side it was rotten right at the connection wall and Im assuming pass side is the same as its leaking water into the carpet...help?
dthomp87
If I remember correctly, you access it from the interior. Remove the kick panel and reach up there, you should be able to find it with a flashlight. I just cut some tubing to fit and all is good! No more leak.
Running20c
