Air Temperature and Pressure Sensor
ffinn
Warrenton, VA
Good morning, I am new to the forum. I have a 2012 supercharged 5.0L Range Rover and I am trying to find the location of the air temperature and pressure sensor (LR21587). I have been told it is located on the top driver's side of the engine, but so far I cannot locate it. Can anyone identify the exact location?
Thanks, Frank
alldazed
ontario
The MAP sensor is on top of the supercharger snout and is fairly obvious just below the rubber hose that connects between the intake plenum and the sc bypass valve actuator.
The MAPT sensor which I think is the one you are looking for is underneath the back of the supercharger. At a guess I would say the supercharger has to come off to get at it. Hope that helps a bit.
Disco2TrailEdit4
