After jacking front end Air suspension not raising
fly boy
Aguascalientes, Mexico
Jacked up the front end of my 2008 LR3 HSE ( just the drivers side) and from the jack points, but air suspension is not raising and vehicle is sitting very low in the front, in the back raises slowly. rides horrible way too bouncy. Suspension Fault amber warning light illuminates - not red, some times suspension raising slowly but quits, I have did a Hard reset (unplug battery) still not working. what cause this? What can I do?
douglastic
first, get a good diagram of the entire EAS system (air lines and electrical)
once you study it isn't THAT complicated, just many areas for problems to show
1. check all electrical connections (compressor, and all valve blocks)
2. check for EAS leaks everywhere (lines, bags, valve blocks)
3. check that your compressor has not died
4. perhaps someone with working spares can help you test and eliminate items?
good luck!
morrisdl
1st step: Get the IIDTOOL or atleast the EAS only version. If you are even a little DIY, it will pay for it self 10X!
@douglastic - Cool! Another Chawton/Alpaca Doug.
