94 RR Classic Hard to Start Everytime
agb2g2
On the fuel pump assembly.
You should have a shrader valve assembly on your fuel rail.
You might also try a shot of starting fuel/carb. spray into the t/body before trying to start it, see what that does.
Is it possible that my situation is caused by a crack in the fuel tank? Since I know is broken and can't fill it up because will leak.
highly possible as the fuel pump can not pressurize the system.
agb2g2
UPDATE!!! Change battery for a new one and the car started without problems like nothing happened. My battery did not gave me any trouble before but for you guys having problems before changing fuel pump or any other component check your battery and replace with a fresh one before dumping money. Also my RR is on the dealer waiting for the new tank to be installed for free :biggrin::argh: Check with your vin # in the dealer if you qualify and if you already spent the money get a refund, recall specify to reimburse your money if already fix the tank. Good luck.
