Hi I ve been reading all kind of post but haven' t solve my problem I have a 94 rr lwb engine 4.2 with 78,000 miles recently I change oil and filter, air filter, clean TB and FM, change water pump and fan cluth it has no termostat installed, today change gasoline filter by the way it was mounted backward from previous owner. The thing is that everytime I start the vehicle takes 40 sec or more to start sometimes a little less but always will start no matter what, did the second position with 5 seg in between and same thing to start, can't check fuel pressure at rail because has no valve, sometimes when vehicle is running it shuts down and light in panel come up but if I push on the gas pedal for some reason revives if done fast enough other wise I have to re start. I try changing the battery and same deal. Before I spent money on things like fuel pump or crank sensor like to hear from guru's. Thanks in advance since my budget is very limited and try to do it my self.
