2015 Evoque Fuel Smell and Leak from Tank
Dr Jron
West Palm Beach, FL
Can see fuel on passenger side of tank, slowly leaking. Pulled rear seat out and moved carpet, even though there is an access panel in the carpet that I didn't see initially. Fuel is not spraying from the top, and doesn't seem to leak from the top of the pump. From what I've read so far, this may be a low pressure pump. Maybe just a gasket is leaking. Appears the access hole is only to remove the connections on the top, since it appears one cannot remove the pump from the hole due to a molded hard foam to protect the tank and the pump appears to come out at an angle. The pictures of pumps for this vehicle don't seem to have the same fittings on the top. Has anyone else had a similar issue and had to drop the tank to replace parts? If so, which parts and where did you purchase them.
