2014 Evoque
JDiehl
Kansas
Well, running into a few issues with the wife's Evoque. These are the codes that popped with the IIDtool. She was driving and the car would not accelerate until it was restarted and then drove normally. The start/stop battery has been dead for sometime which is fine by me because a hot turbo with no oil flow leads to problems. I changed out the main battery thinking it may have been a low voltage issue to no avail. I have owned the vehicle since new and performed most of the maintenance myself. I may need to unlock her VIN to the IIDtool to dive a little deeper. Any ideas or trouble shooting tips?
JD
L538 - Evoque 2014
Vehicle scanned on 24-10-2023 10:41
Using IIDTool BT V4.0 B2803
ABS-Brake Module
  • U0001-82 (28) High speed CAN communication bus - Bus signal/message failure - alive/sequence counter is incorrect/not updated
    ( on 11-09-2023 05:50:42 at 76386 mi )
GWM-Gateway module
  • B13C5-92 (AF) Secondary battery - Component failure - performance or incorrect operation
    ( on 24-10-2023 10:38:50 at 77284 mi )
IPC-Instrument Pack
  • U0001-87 (2C) High speed CAN communication bus - Bus signal/message failure - missing a message
    ( on 09-10-2023 20:51:36 at 77032 mi )
TCM-Transmission
  • P0710-64 (E8) Transmission fluid temperature sensor A circuit - Algorithm based failure - signal plausibility failure
    ( on 09-10-2023 20:51:35 at 77032 mi )
JDiehl
Kansas
Update
Reset the battery management all issues have not returned.
JD
