2010 Land Rover LR4 - Suspension Fault
ac6567
Oakland, CA
The suspension on my '10 LR4 is stuck on 'normal height' but is not raising. When driving, the ride is extremely bouncy from the front of the vehicle.
Here are my fault codes:
  • P0526 - Fan Speed Sensor Circuit
  • P0430 - Catalyst System Efficiency Below Threshold
  • C0031-64 - Front left wheel speed sensor
  • C0034-64 - Front right wheel speed sensor
  • U0421-68 - Invalid data received from ride level control module
  • U3003-62 - Battery voltage
No offroad driving.
Any suggestions as to what the issue is and the likely fix?
You've got a bunch of unrelated codes. Clear them and see what comes back.
Cthehentz
Las Vegas
Check your battery voltage while engine is off and then while it is running, when my alternator failed the entire dash lit up. Resting voltage was around 12.5v, idling voltage is around 14.5v.
Al Pizzica
PA
Yeah, whenever battery voltage comes up, address that code first and chances are the others will clear.
Both of our LR4s threw all kinds of random codes when the batteries were dying.
