2006 Supercharged - Emission Code
b3nemeth
My check engine light came on and the code that came up was P0441: "Evaporative Emission System Incorrect Purge Flow". I've read that for other, older Land Rover models this means replace the purge valve. Does anyone know if this also pertains to newer Range Rovers, i.e. 2006?
No, only 443, 444 and 445 refer to the purge valve, I would start looking for a cracked vacuum hose.
LandRvrTech
What is the last 8 of your VIN number? There is a bulletin out for certain '06 Range Rovers with this code for updated PCM software calibrations....
Jadaboss
Ive have the same code for 2006 supercharged full size range rover, & when I research the code its says its for the purge valve, but did find that it was something else that was causing the issue?
Jadaboss
Po441 error code
RoverGuy7
P0441 is a purge flow fault.
It is usually the valve itself, but there are other possible causes, such as a restriction in the vapor line, or in the inlet filter or vent valve.
Step one with the is going to be replace the valve, it's not cheap, but it's pretty easy to replace.
redline8725
USA
same code on my 2011 RR HSE sport, anyone else have the same problem on this year ?
