2006 LR3 horn is not working
c3c
Just like the title says. I have checked the fuse in the glove box and it is fine. Does anyone know how to fix it?
ncburch22
Check the wiring on the horn itself. It may of come loose from the connection.
c3c
Checked the wiring...everything is snug
EIGHTLUG
Check for the proper voltage at the connection as someone pushes the horn button. If you have voltage R2 the horn. If not start tracing power all the way back to the horn button.
c3c
I thought someone might say this... Well I'm not the most knowledgeable when it comes to voltage meters.....
EIGHTLUG
Pick up a simple 12/24V tester that just relies on a light for a go-no-go. Light on, good. No light, bad. Every auto part retailer sells them, cheap too.
proslambanomenos
wet inside
i realize i'm resurrecting an old thread but i removed my high-note horn tonight and it is waterlogged inside. water's getting in and it's not coming back out.
Rendak
