N
nedkelly
The Plot Thickens
OK.
I took a trip to the land rover garage - which i assume is run as a franchise. more on that later.
They did not perform any chemical test prior to removing the head. It appears that there is no damage to the head - although this will be tested next week. There is damage to one of the Bolt holes - which may well have been done by the garage. The reason the garage is now claiming that a new engine is required is because it is impossible to use a helicoil (or similar) to replace the damaged bolt thread. Thats right. One damaged bolt thread (in the middle of the block) and they are suggesting that the only remedy is a new (reconditioned) engine.
After some delicate negotiations with a lawyer here in Spain and the Ex owner of the vehicle - we have now decided to:
1) Take the car from the 'official' dealer to an engineer
2) Crack Test the head
3) Helicoil the damaged bolt hole
4) Check for any other damage to the engine
5) New Gasket, New Radiator
I will pay 25% of the repairs. Spanish Law allows me to claim all costs, replacement or return of my money for 1 YEAR - under a law in the Civil Code which caters for 'Hidden Problems'
Now back to the dealer. I get the feeling (from the youthful mechanics) that these guys are in a habit of replacing old for new - very little repairing is done as any future issues can be deferred to Land Rover directly. After all, if it weren't for this attitude - why is there a thriving 'non official' mechanical industry. To replace an entire engine due to 1 thread in the block needing a helicoil seems to be a scam at best. If these guys are running as a franchise then their motivation is no risk profit. sure they can do the diagnostics... but dont ask them to do any engineering as it is far more risky than replacing old for new - and turning to the manufacturer if it all goes to ****.
Anyone have any experience with Helicoils. Are they able to withstand the pressure and temperature of a car engine.
Am i talking out of my exhaust pipe?
OK.
