1999 2.5 P38 - Overheating Problem -Help!
feenom
Over heating issue...
Try bleeding your radiator more . I had to do this several times until I got all the air out but seems to be working now. i hope this helps
I'm having the same problem. You said you bleed the air in your rad. How did you do thta exactly?
feenom
Over Heating Issue...
The Land Rover Garage have suggested a new engine at €5000. Not bad seeing that i paid €10k for the car.
Dont i feel like a %^&*$% idiot.
NEVER AGAIN:mad:
Ned,
I'm having the same issue. Can you let me know ASAP how you resolved this?
Tyler
Six months ago I replaced the water pump, today I replaced the thermostat. BUT I am still having an over heating issue. I bleed the coolant and put all the fluids in gradually with the expansion tank cap off. The oil seems the right colour. I even did an oil change to see if there might be coolant leaking, but the truck still over heating fairly quickly (ten-fifteen minutes). Please help!!!
