AC condenser, leaking into the passenger footwell
tolgauysal
sydney
hi all,, need some HELP!!!
my ac condenser seems to be leaking into the footwell, ive read that the condenser drain pipe gets clogged from time to time,, make sense with all the mud ive been going through
has anyone had issues like this ? also does anyone know where the drain pipes are located under the car, i cant seem to find them
unfortunately when i run the AC no water comes out the bottom ( only from the footwells)
thanks again for the help everyone
i have a 2013 110
Bethany
Texas
That is a very common issue, especially in D2s. I know you said you have a different model.
I gingerly disconnect the drain tube and insert a wire to clean it out. On my D2, I have to do this a couple times per year.
prattyroxoz
Brisbane, Australia
This happened to my Freelander 2 so not sure if it applies to the Defender. Google.... Freelander leaky AC drain hose fix .... for pictures on the 4x4 site
The drain 'pipe' (more of a small hose) was accessed by removing the panels in the interior between the footwells. There was an AC condensate pipe join that when blocked drains into the footwell rather than outside.
BigBriDogGuy
Bellingham, WA (USA)
I just got my A/C recharged and now I noticed a small puddle of water in my driveway. It's water. Not coolant, not oil, plain water. I took a bit of toilet paper and let it drip onto it. No smell. No color. No oiliness. Could this be from a drain pipe?
In the pics below, you can see a drop of water on the pipe, but it is dropping from above, hitting the pipe, rolling down the side, forming a drop and then falling to the inclined driveway. By the way, it has stopped now.
BigBriDogGuy
Update: Whatever it is, seems to be a non-issue. Rig is running fine and I don't see any more water puddles underneath. I just don't know where the A/C condenser is supposed to drain. If that's the right location, then it looks like it is just another false alarm.
Rover Range
Texas
Perfectly normal.
