very sudden loud clicking and fan noise... is my rover near death?
RoverThinker
IA
drove my '14 lr4 (~80K) to gym last night, gym this morning and no problems. on my way to work this morning out of nowhere it starts making a noise that went from semi noticeable with window down to extremely noticeable. upon start up - extremely loud clicking paired with a noise that reminds me of putting a playing card in your bike spoke - amplified. No lights on, not overheating. it seems to drive okay (i drove it 2 miles down the road to the local rover shop) but the noise is absolutely atrocious (not to mention embarrassing). i turned off the air conditioning completely and it seemed to lessen.
But i'm terrified. is it about to die? is it a fan? exhaust? engine? I'm posting here because to top it all off, when i called owner of shop to let him know i dropped it - they're closed for the week. Clearly, i have no mechanical skills and waiting til next week i might die from anxiety.
(last year i had the coolant issue where it suddenly over heated. it was leaking and i had that repaired - shortly after a hose came loose but again, quick repair and no further issue)
No the answer you are wanting right now, but nobody here will have a clue what it is.
But probably just something stuck somewhere, if you have no codes and no problems otherwise.
roverman
Did you check for playing cards in your spokes?
I kid, I kid. But yeah a lot more info would be needed. Internet diagnosing is pretty tough.
Post up a video or sound file. Does the speed of the sound increase/decrease with the engine RPM? If not - fan clutch. If it does change, possibly supercharger coupler (not a bad fix). Could also be fuel pump. Hard to say without hearing it.
equalizer
Arizona
I am ignorant on the matter apparently. I would have thought that the fan clutch either engages or disengages with the utility belt. Thus higher RPMs --> Faster fan speed.
How can the fan keep constant speed?
Or am I misinterpreting what you wrote above?
So the fan is a viscous fan.
It's connected through the engine through a viscous clutch that can vary engagement levels, dependent on a variety of factors. The fan speed will vary with engine RPM. One of the big items that varies the speed is if the air conditioning is on or not, which is why that may have been changing your noise.
Hopefully it's something simple like that. I had the cooling fan get stuck fully on, and had it replaced a while back (Probably 60k miles or so)
When the viscous clutch goes bad, it often causes a clicking noise. That clicking noise tends to be like a clock - it doesn‘t really change much with the engine RPM - at least when I’ve heard it. I believe the noise is actually the clutch solenoid turning on and off repeatedly, so its not dependent on the engine speed.
So - yes, the fan speed can change with RPM, but the typical “clicking” associated with what seems to be most common failure mode on these fans tends not to change with engine RPM.
jlach993
Fresh Meadows Queens NY
Hey dude lol we need more info to go on! Open up the hood. Start it up briefly. Take a vid and try and figure out what it is…if its the fan area or coming from the actual engine block.
PaulLR3
Boston
As others above noted, probably the fan clutch is seizing. I think mine went bad around 80K miles as well.
