gsxr
I'll second that question!!!Wait, the whole car is shaking? Is it moving the steering wheel side to side, and that's shaking the whole car, or is the whole car shaking, and you're feeling it in the steering wheel?
How many miles on your LR4?
Have the front lower control arm bushings been looked at or replaced? Those are the ones that go out most often, not the upper ones.
Also, you may want to think twice about having your full residential address in your profile.
Spacers... hmmm. Does anyone know if the LR4 wheels are hubcentric, meaning the hole in the center of the wheel uses the hub to center the wheel? If so, the spacers COULD be causing a problem.. I also had to add 5mm spacers to clear the calipers but doubt that is the problem.
