Parts identification - help needed
lrovy
France
Hi Guys,
Your help would be appreciated in identifying below parts - disclaimer - I did go through workshop manual and could not find enough info to be able to order what would be needed:
1. Where to attach this one (and if any other there on pics), what parts are needed?
0-02-05-bed36ca9e07d0da7c090d451441b820a40b9b06788efa0c1f692b006c21ea60f_1f9d788a8cb411.jpg
0-02-05-217196929046b2459246ea1a365a05a72de982175dabb0699cb3813fcb40815e_1f9d788a83721d.jpg
0-02-05-4edc6d479f03a68f8aa8d39d3a95d92e955a1a2fed4a0f639815d2088ed3abd7_1f9d788a8c8ab6.jpg
2. What is this? (sensor?) What's needed and where it should be attached? It is loose at the moment. It's on some sort of relatively hard tube though a bit flexible.
TBC - due to limits of attached files per single post.
lrovy
France
3. Just fixings missing - what are part number for these? Again, can't find it (just probably missing the keywords or something - did my search already and feel dumb that couldn't find it - hence help needed).
These two tubes are part of upper hoses and are on top of compressor. The black portion is air chamber
4. Need to identify what this socket/plug was for, I'd like to replace it and get it fixed. Nothing is missing/disconnected or the mechanic did not connect it. It is behind right headlamp (headlamp removed on pics).
5. Grill fixing points missing - this one already ordered and what came is too large and doesn't fit into the metal frame (this frame is from LR3!!! not LR4 post-lift - it shouldn't matter though maybe this is the little detail where it matters. Need to put LR4 post-lift grill there. The grill itself fits fine, just small rubber/plastic elements are missing so the grill would not rattle.).
alldazed
ontario
Hi Guys,
View attachment 24381View attachment 24382
View attachment 24383View attachment 24384
I think the red circled ones in the top of the engine bay are breathers for the diffs.
