Overheating... Completely at a loss.
jwest
Seattle WA
Now this is a good thread for learning! I have not used it yet but have been told the latest IIDtool with bluetooth provides some system monitoring. Wondering now if coolant temp is one of the items. Would be nice to have on hand when towing and such.
Codename Duchess
I'm just using a regular old OBDII scanner via Torque Pro on my phone.
(Yes, I know I need a proper tool) :) But for now that's what I'm stuck with.
I have the entire housing, I just split it up in the interest of saving time, as well as I didn't want to get into the situation of 'Well I might as well replace that too aaaaaaaand I need another part'
angelregio
Houston
I have the same problem change the Thermostat and or whit the housing change water pump twice use 2 different brands one work better than the other I don't see any leaks
take all the hoses apart to see the condition (OK) flush the radiator it looks like it was ok but next morning heats up again run the test for the heat gasket no change of color problem remains AutoZone and parts geek don't want nothing whit me anymore. I don't want to go to the dealer last time they charge me 2500 just to replace the suspension compressor which it cost only $500 I ask them if they can cut and program a new Key and they want $500 for a new one BC I did not buy from them even do is a land rover product THEY ARE Thieves whit a license
angelregio
Houston
I need Help Guys Overheating I follow all the instructions and recommendations above, change thermostat whit the housing (2), change water pump (2) take all the hoses and check for problems they all ok. but the problem remains last thing I doing is flushing the radiator
morrisdl
You are at the stealership's mercy for keys and alignments, but everything else you can do at home or independent shops.
Sturgeon
