OEM Brush Bar w/ Winch
GrahamWelland
The tyres are Nitto Grapplers 285/60/18. They don't rub at all in normal use. The only time I have had an issue is when reversing with full lock which is enough for the front driver side tyre to rub against the suspension sensor wiring harness and you can easily break this. I had to have the harness wires dressed out of the way otherwise you'll cut it with the tyre.
Hanzo
The Nitto's are good tires as are the Cooper Zeons... This size doesn't rub... if you're interested in learning more, do a search as there are about a million tire threads on this forum.
cools thanks will do...:)
