leak at oil pressure switch
jastutte
I have already tightened it once about six or seven months ago. that took care of the leak for a while. now it's back. i looked in the rave and can't tell from it whether or not the oil pressure switch has a gasket. i want to fix this leak if possible. is there a washer or gasket of some sort that needs to be renewed or do I just tighten the oil pressure switch again?
thanks,
Remove the switch and use some permitex or some plumbers tape.
aemnky606
it does not have one i took mine out and found a o-ring that fit it and put some plumbers grease on it and off i went and no problems.
