Johnson loft and spacers
David Garcia
United States
Maybe you can check spacer compatibility. Ensure that the spacers you are using are compatible with your vehicle's make and model. Sometimes, spacers may not have the correct specifications, leading to improper fitment. In this case, I would recommend considering BONOSS Land Rover wheel spacers.
itsaguything
Manotick, On, Canada
I see many messing with the geometry "for looks" which can really negatively impact "performance and safety".
So, I always consider this: https://www.wheel-size.com/calc/
And in particular, the effects of messing with the scrub angle.
Of course, if the vehicle is a garage queen, mall crawler, and main drag cruiser; it probably won't matter much.
But in the inclement weather or, at higher speeds; absolutely.
fwiw.
Cheers!
